Coq Modulo Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Coq Modulo Theory
Pierre-Yves Strub
  • Fonction : Auteur
  • PersonId : 857170
Coq Modulo Theory (CoqMT) is an extension of the Coq proof assistant incorporating, in its computational mechanism, validity entailment for user-defined first-order equational theories. Such a mechanism strictly enriches the system (more terms are typable), eases the use of dependent types and provides more automation during the development of proofs. CoqMT improves over the Calculus of Congruent Inductive Constructions by getting rid of various restrictions and simplifying the type-checking algorithm and the integration of first-order decision procedures. We present here CoqMT, and outline its meta-theoretical study. We also give a brief description of our CoqMT implementation.
csl-2010.pdf (158.1 Ko) Télécharger le fichier
inria-00497404 , version 1 (05-07-2010)
Pierre-Yves Strub. Coq Modulo Theory. 19th EACSL Annual Conference on Computer Science Logic, Aug 2010, Brno, Czech Republic. pp.529--543, ⟨10.1007/978-3-642-15205-4_40⟩. ⟨inria-00497404⟩
228 Consultations
446 Téléchargements
