Feature Preserving Mesh Generation from 3D Point Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nader Salman
  • Fonction : Auteur
  • PersonId : 862778
Mariette Yvinec
Quentin Mérigot
We address the problem of generating quality surface triangle meshes from 3D point clouds sampled on piecewise smooth surfaces. Using a feature detection process based on the covariance matrices of Voronoi cells, we first ex- tract from the point cloud a set of sharp features. Our algorithm also runs on the input point cloud a reconstruction process, such as Poisson reconstruction, providing an implicit surface. A feature preserving variant of a Delaunay refinement process is then used to generate a mesh approximating the implicit surface and containing a faithful representation of the extracted sharp edges. Such a mesh provides an enhanced trade-off between accuracy and mesh complexity. The whole process is robust to noise and made versatile through a small set of parameters which govern the mesh sizing, approximation error and shape of the elements. We demonstrate the effectiveness of our method on a variety of models including laser scanned datasets ranging from indoor to outdoor scenes.
salman_yvinec-SGP10.pdf (3.86 Mo) Télécharger le fichier
inria-00497632 , version 1 (05-07-2010)
  • HAL Id : inria-00497632 , version 1
Nader Salman, Mariette Yvinec, Quentin Mérigot. Feature Preserving Mesh Generation from 3D Point Clouds. Computer Graphics Forum, Jul 2010, Lyon, France. pp.1623-1632. ⟨inria-00497632⟩
Collections
INRIA INRIA2 ANR
610 Consultations
2729 Téléchargements
