Multi-scale Geometric Modeling of Ambiguous Shapes with Toleranced Balls and Compoundly Weighted alpha-shapes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Frédéric Cazals
Tom Dreyfus
  • Fonction : Auteur
  • PersonId : 872912
Dealing with ambiguous data is a challenge in Science in general and geometry processing in particular. One route of choice to extract information from such data consists of replacing the ambiguous input by a continuum, typically a one-parameter family, so as to mine stable geometric and topological features within this family. This work follows this spirit and introduces a novel framework to handle 3D ambiguous geometric data which are naturally modeled by balls. First, we introduce {\em toleranced balls} to model ambiguous geometric objects. A toleranced ball consists of two concentric balls, and interpolating between their radii provides a way to explore a range of possible geometries. We propose to model an ambiguous shape by a collection of toleranced balls, and show that the aforementioned radius interpolation is tantamount to the growth process associated with an additively-multiplicatively weighted Voronoi diagram (also called compoundly weighted or CW). Second and third, we investigate properties of the CW diagram and the associated CW $\alpha$-complex, which provides a filtration called the $\lambda$-complex. Fourth, we propose a naive algorithm to compute the CW VD. Finally, we use the $\lambda$-complex to assess the quality of models of large protein assemblies, as these models inherently feature ambiguities.
RR-7306.pdf (869.19 Ko) Télécharger le fichier
inria-00497688 , version 1 (07-07-2010)
  • HAL Id : inria-00497688 , version 1
Frédéric Cazals, Tom Dreyfus. Multi-scale Geometric Modeling of Ambiguous Shapes with Toleranced Balls and Compoundly Weighted alpha-shapes. [Research Report] RR-7306, INRIA. 2010, pp.32. ⟨inria-00497688⟩
162 Consultations
173 Téléchargements
