Assessing the Quality of your Software with MoQam - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Over the last decade, the need for quality in software has increased. Several quality models have been proposed [4, 6, 11]. These mod- els emphasize the need to have quality checks while developing a software program. As far as we are aware of, no model to assess quality of existing software have reached a significant acceptance. This paper describes the Qualixo quality model. Qualixo is an open-source quality model developed by several companies and pushed further in the context of the Squale research project. Ac- cording to Marinescu and Ratiu [9], Qualixo can be classified as a Factor-Criteria-Metrics quality model. Qualixo is being applied in large companies such as AirFrance or PSA. It uses measurements to assess software quality. These measurements cover a number of different aspects of a software, including specification accuracy, programming rules, and test coverage. Qualixo has been origi- nally implemented on top of Eclipse. In this paper we present Mo- Qam (Moose Quality Assessment Model), the implementation of the Qualixo quality model in the Moose open-source reengineering environment.
Lava08a-Famoosr2008-MoQam.pdf (107.54 Ko) Télécharger le fichier
inria-00498482 , version 1 (07-07-2010)
  • HAL Id : inria-00498482 , version 1
Jannik Laval, Alexandre Bergel, Stéphane Ducasse. Assessing the Quality of your Software with MoQam. FAMOOSr 2008 - 2nd Workshop on FAMIX and Moose in Reengineering, Oct 2008, Antwerp, Belgium. ⟨inria-00498482⟩
181 Consultations
82 Téléchargements
