DC Programming Approach for Resource Allocation in Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nikola Vucic
  • Fonction : Auteur
  • PersonId : 873880
Martin Schubert
  • Fonction : Auteur
  • PersonId : 873882
We consider the problem of sum rate maximization with joint resource allocation and interference mitigation by multiantenna processing in wireless networks. The denominators in the users' signal-to-interference-plus-noise expressions are assumed to be representable in the form of matrix-based, concave interference functions. It is shown that the problem of interest for this system model can be readily rewritten as a minimization of a difference of convex functions. Based on this representation, an iterative algorithm with guaranteed convergence is employed to calculate possibly suboptimal solutions of the main problem, which is known to be NP-hard. The proposed technique enables achieving a large portion of the globally optimal sum rate. It is also very efficient and rather general in terms of allowing interesting extensions, compared with the related results from the literature.
p360-vucic.pdf (361.25 Ko) Télécharger le fichier
inria-00502213 , version 1 (13-07-2010)
  • HAL Id : inria-00502213 , version 1
Nikola Vucic, Shuying Shi, Martin Schubert. DC Programming Approach for Resource Allocation in Wireless Networks. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.360-366. ⟨inria-00502213⟩
Collections
WIOPT2010
67 Consultations
968 Téléchargements
