Mirrored Variants of the (1,2)-CMA-ES Compared on the Noiseless BBOB-2010 Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Nikolaus Hansen
Derandomization by means of mirroring has been recently introduced to enhance the performances of $(1,\lambda)$-Evolution-Strategies (ESs) with the aim of designing fast robust local search stochastic algorithms. This paper compares on the BBOB-2010 noiseless benchmark testbed two variants of the (1,2)-CMA-ES where the mirroring method is implemented. Independent restarts are conducted till a total budget of $10^{4} D$ function evaluations per trial is reached, where $D$ is the dimension of the search space. The results show that the improved variants increase the success probability on 5 (respectively 7) out of 24 test functions in 20D and at the same time are significantly faster on 9 (10) functions in 20D by a factor of about 2--3 (2--4) for a target value of $10^{-7}$ while in no case, the baseline (1,2)-CMA-ES is significantly faster on any tested target function value in 5D and 20D.
ws1p18-augerAuthorVersion.pdf (1.82 Mo) Télécharger le fichier
inria-00502435 , version 1 (14-07-2010)
Anne Auger, Dimo Brockhoff, Nikolaus Hansen. Mirrored Variants of the (1,2)-CMA-ES Compared on the Noiseless BBOB-2010 Testbed. GECCO workshop on Black-Box Optimization Benchmarking (BBOB'2010), Jul 2010, Portland, OR, United States. pp.1551-1558, ⟨10.1145/1830761.1830772⟩. ⟨inria-00502435⟩
199 Consultations
185 Téléchargements
