Extending Coq with Imperative Features and its Application to SAT Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Coq has within its logic a programming language that can be used to replace many deduction steps into a single computation, this is the so-called reflection. In this paper, we present two extensions of the evaluation mechanism that preserve its correctness and make it possible to deal with cpu-intensive tasks such as proof checking of SAT traces.
fastcoq.pdf (197.33 Ko) Télécharger le fichier
inria-00502496 , version 1 (15-07-2010)
inria-00502496 , version 2 (26-08-2010)
  • HAL Id : inria-00502496 , version 1
Michaël Armand, Benjamin Grégoire, Arnaud Spiwack, Laurent Théry. Extending Coq with Imperative Features and its Application to SAT Verification. Interactive Theorem Proving, Jul 2010, Edinburgh, United Kingdom. ⟨inria-00502496v1⟩
435 Consultations
543 Téléchargements
