Controlling Background Subtraction Algorithms for Robust Object Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper presents a controller for background subtraction algorithms to detect mobile objects in videos. The controller has two main tasks. The first task is to guide the background subtraction algorithm to update its background representation. To realize this task, the controller has to solve two important problems: removing ghosts (background regions misclassified as object of interest) and managing stationary objects. The controller detects ghosts based on object borders. To manage stationary objects, the controller cooperates with the tracking task to detect faster stationary objects without storing various background layers which are difficult to maintain. The second task is to initialize the parameter values of background subtraction algorithms to adapt to the current conditions of the scene. These parameter values enable the background subtraction algorithms to be as much sensitive as possible and to be consistent with the feedback of classification and tracking task.
icdp2009.pdf (678.17 Ko) Télécharger le fichier
inria-00502932 , version 1 (16-07-2010)
  • HAL Id : inria-00502932 , version 1
Anh-Tuan Nghiem, François Bremond, Monique Thonnat. Controlling Background Subtraction Algorithms for Robust Object Detection. International conference on Imaging for Crime Detection and Prevention, Dec 2009, London, United Kingdom. ⟨inria-00502932⟩
Collections
INRIA INRIA2
168 Consultations
221 Téléchargements
