On the Optimal Design of MAC Protocols in Multi-Hop Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract—In this paper, we present our results on the performance of MAC protocols in multi-hop wireless ad hoc networks in terms of the newly proposed metric “aggregate multi-hop information efficiency”. This metric captures the impact of the traffic conditions, the quality of service requirements for rate and correct packet reception, the number of hops and distance between a sender and its destination, and the outage probability for packet transmissions. Our network model considers a wireless network where nodes are distributed according to a homogeneous 2-D Poisson point process. Packet are generated following a Poisson distribution, and are forwarded to their destinations through a variable number of hops. Approximate expressions are derived for the outage probability of the ALOHA and CSMA MAC protocols, and validated with simulations. Various modifications of these protocols are considered, and their performances are compared. Moreover, an analytical procedure is presented to optimally design the communication so the multi-hop information efficiency performance of the network can be maximized.
p602-kaynia.pdf (326.68 Ko) Télécharger le fichier
inria-00503077 , version 1 (16-07-2010)
  • HAL Id : inria-00503077 , version 1
Mariam Kaynia, Pedro H. J. Nardelli, Paulo Cardieri, Matti Latva-Aho. On the Optimal Design of MAC Protocols in Multi-Hop Ad Hoc Networks. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.602-607. ⟨inria-00503077⟩
Collections
WIOPT2010
116 Consultations
121 Téléchargements
