A Two-Stage Approach to WLAN Planning: Detailed Performance Evaluation Along the Pareto Frontier - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Andreas Eisenblätter
  • Fonction : Auteur
  • PersonId : 874119
Hans-Florian Geerdes
  • Fonction : Auteur
  • PersonId : 874120
James Gross
  • Fonction : Auteur
  • PersonId : 874121
Oscar Puñal
  • Fonction : Auteur
  • PersonId : 874122
Jonas Schweiger
  • Fonction : Auteur
  • PersonId : 874123
This paper proposes an efficient solution to the open problem of network planning for large-scale WLAN deployments. WLAN performance is governed by the CSMA-CA protocol, whose dynamic effects are difficult to capture. Accurate performance evaluation depends on simulations and takes time. A detailed analysis of dozens candidate designs with varying AP positions and channel assignments during network planning is therefore infeasible. In our solution, we first identify few good candidate designs using a multi-criteria optimization model, which features notions of cell overlap and station throughput. These candidate designs are taken from the corresponding Pareto frontier. In the second step, we evaluate the performance of the candidate designs by means of simulations. We apply our method to a realistic, large-scale planning scenario for an indoor office environment. The detailed simulations reveal important characteristics of the candidate designs that are not captured by the optimization model. The resulting performance differs significantly across the candidate designs. Hence, this approach successfully combines the benefits of mathematical optimization and simulations, yet avoiding their individual drawbacks.
p232-eisenblatter.pdf (1.39 Mo) Télécharger le fichier
inria-00504015 , version 1 (19-07-2010)
  • HAL Id : inria-00504015 , version 1
Andreas Eisenblätter, Hans-Florian Geerdes, James Gross, Oscar Puñal, Jonas Schweiger. A Two-Stage Approach to WLAN Planning: Detailed Performance Evaluation Along the Pareto Frontier. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.232-241. ⟨inria-00504015⟩
Collections
WIOPT2010
131 Consultations
653 Téléchargements
