Wavelet Expansion and High-order Regularization for Multiscale Fluid-motion Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We consider a novel optic flow estimation algorithm based on a wavelet expansion of the velocity field. In particular, we propose an effi- cient gradient-based estimation algorithm which naturally encompasses the es- timation process into a multiresolution framework while avoiding most of the drawbacks common to this kind of hierarchical methods. We then emphasize that the proposed methodology is well-suited to the practical implementation of high-order regularizations. The powerfulness of the proposed algorithm and regularization schemes are finally assessed by simulation results on challenging image sequence of turbulent fluids.
RR_7348.pdf (477.85 Ko) Télécharger le fichier
inria-00505780 , version 1 (26-07-2010)
inria-00505780 , version 2 (28-07-2010)
  • HAL Id : inria-00505780 , version 1
Pierre Dérian, Patrick Héas, Cédric Herzet, Etienne Mémin. Wavelet Expansion and High-order Regularization for Multiscale Fluid-motion Estimation. [Research Report] RR-7348, 2010. ⟨inria-00505780v1⟩
223 Consultations
216 Téléchargements
