An Algorithm for Adapting Cases Represented in an Expressive Description Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Julien Cojan
  • Fonction : Auteur
  • PersonId : 836380
Jean Lieber
This paper presents an algorithm of adaptation for a case-based reasoning system with cases and domain knowledge represented in the expressive description logic ALC. The principle is to first pretend that the source case to be adapted solves the current target case. This may raise some contradictions with the specification of the target case and with the domain knowledge. The adaptation consists then in repairing these contradictions. This adaptation algorithm is based on an extension of the classical tableau method used for deductive inference in ALC.
definitif.pdf (195.94 Ko) Télécharger le fichier
inria-00506078 , version 1 (27-07-2010)
Julien Cojan, Jean Lieber. An Algorithm for Adapting Cases Represented in an Expressive Description Logic. 18th International Conference on Case-Based Reasoning - ICCBR 2010, Jul 2010, Alessandria, Italy. pp.51-65, ⟨10.1007/978-3-642-14274-1⟩. ⟨inria-00506078⟩
105 Consultations
224 Téléchargements
