Formal Specification and Validation of Security Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We propose a formal framework for the specification and validation of security policies. To model a secured system, the evolution of security in- formation in the system is described by transitions triggered by authorization requests and the policy is given by a set of rules describing the way the corresponding decisions are taken. Policy rules are constrained rewrite rules whose constraints are first-order formulas on finite domains, which provides enhanced expressive power compared to classical security policy specification approaches like the ones using Datalog, for example. Our specifications have an operational semantics based on transition and rewriting systems and are thus executable. This framework also provides a common formalism to define, compare and compose security systems and policies. We define transformations over secured systems in order to perform validation of classical security properties.
FormalValidation2010.pdf (290.51 Ko) Télécharger le fichier
inria-00507300 , version 1 (30-07-2010)
inria-00507300 , version 2 (22-02-2011)
  • HAL Id : inria-00507300 , version 1
Tony Bourdier, Horatiu Cirstea, Mathieu Jaume, Hélène Kirchner. Formal Specification and Validation of Security Policies. 2010. ⟨inria-00507300v1⟩
364 Consultations
482 Téléchargements
