Probabilistic Contracts for Component-based Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We define a probabilistic contract framework for describing and analysing component-based embedded systems, based on the theory of Interactive Markov Chains (IMC). A contract specifies the assumptions a component makes on its context and the guarantees it provides. Probabilistic transitions allow for uncertainty in the component behavior, e.g., to model observed black-box behavior (internal choice) or reliability. An interaction model specifies how components interact. We provide the ingredients for a component-based design flow, including (1) contract satisfaction and refinement, (2) parallel composition of contracts over disjoint, interacting components, and (3) conjunction of contracts describing different requirements over the same component. Compositional design is enabled by congruence of refinement.
RR-7328.pdf (474.41 Ko) Télécharger le fichier
inria-00507785 , version 1 (31-07-2010)
inria-00507785 , version 2 (01-10-2013)
  • HAL Id : inria-00507785 , version 1
Dana N. Xu, Gregor Goessler, Alain Girault. Probabilistic Contracts for Component-based Design. [Research Report] RR-7328, 2010. ⟨inria-00507785v1⟩
Collections
INRIA-RRRT
337 Consultations
299 Téléchargements
