Using Graphics Hardware to Speed-up Visibility Queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of graphics tools Année : 2000
We present a visibility method that takes advantage of the graphics hardware to give fast answers to visibility queries. Our visibility method is designed to solve two types of visibility queries: point-based visibility queries, where several visibility queries share the same origin, and plane- based visibility queries, where several visibility queries have their origins on the same plane. Both occur frequently in global illumination algorithms. Combining the speed given by graphics hardware with a software heuristic to avoid reliability problems, our visibility method is signicantly faster than ray-casting, and still gives the same results.
paper.pdf (1002.65 Ko) Télécharger le fichier
piece1.eps (5.3 Mo) Télécharger le fichier
piece2.eps (5.28 Mo) Télécharger le fichier
shirley.eps (4.71 Mo) Télécharger le fichier
shirley2.eps (4.71 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00509979 , version 1 (17-08-2010)
  • HAL Id : inria-00509979 , version 1
Nicolas Holzschuch, Laurent Alonso. Using Graphics Hardware to Speed-up Visibility Queries. Journal of graphics tools, 2000, 5 (2), pp.33-47. ⟨inria-00509979⟩
170 Consultations
312 Téléchargements
