A general model for the simulation of room acoustics based on hierarchical radiosity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
We present a new method to compute the impulse response (IR) of a given virtual room based on hierarchical radiosity. Unlike previous work, our approach can treat complex geometries and is listeningposition- independent. Moreover, complex phenomena such as sound diffraction are also taken into account.
sketch.pdf (36.46 Ko) Télécharger le fichier
inria-00510090 , version 1 (17-08-2010)
  • HAL Id : inria-00510090 , version 1
Nicolas Tsingos, Jean-Dominique Gascuel. A general model for the simulation of room acoustics based on hierarchical radiosity. SIGGRAPH'97 technical sketch, 1997, Los angeles, United States. ⟨inria-00510090⟩
129 Consultations
161 Téléchargements
