Hierarchical Lighting Simulation for Outdoor Scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
Lighting algorithms for outdoor scenes suffer from the sheer geometric and lighting complexity of such environments. In this paper we introduce an efficient, hierarchical solution to the problem of outdoor illumination. Data structures and sampling algorithms are presented, permitting the integration of complex and natural objects in a hierarchical radiosity simulation system. This new approach allows the hierarchical simulation of radiant energy exchanges in outdoor scenes for the first time, including terrain and botanical models as well as sunlight and skylight. This is accomplished by providing the necessary tools to treat terrain meshes as a hierarchy of light-exchanging objects, as well as an efficient hierarchical representation for the sky dome. In addition, refinement criteria are adapted to the particular characteristics of natural lighting. Results of our implementation are presented including naturally-lit images of terrain-maps, trees and buildings.
DaubertEGRW97.pdf (239.81 Ko) Télécharger le fichier
inria-00510097 , version 1 (17-08-2010)
  • HAL Id : inria-00510097 , version 1
Katja Daubert, Hartmut Schirmacher, François X. Sillion, George Drettakis. Hierarchical Lighting Simulation for Outdoor Scenes. 8th Eurographics workshop on Rendering, 1997, Saint Etienne, France. ⟨inria-00510097⟩
169 Consultations
218 Téléchargements
