Constructive Fractal Geometry : constructive approach to fractal modeling using language operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
Joëlle Thollot
Eric Tosan
  • Fonction : Auteur
Using a generalization of the IFS model, we try to etablish relations between operations over languages and operations attractors. This leads us to a constructive approach of fractal geometry.
fractal_geometry_thollot_1995.pdf (5.29 Mo) Télécharger le fichier
Format : Figure, Image
inria-00510124 , version 1 (30-11-2010)
  • HAL Id : inria-00510124 , version 1
Joëlle Thollot, Eric Tosan. Constructive Fractal Geometry : constructive approach to fractal modeling using language operations. Graphics Interface (GI'95) Proceedings, the Canadian Human-Computer Communications Society, May 1995, Québec, Canada. ⟨inria-00510124⟩
Collections
UNIV-LYON1 UDL
185 Consultations
255 Téléchargements
