N-Buffers for efficient depth map query - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2005
We introduce the N-buffer as a tool for multiresolution depth map representation. This neighborhood buffer encodes the value and position of local depth extrema at different scales in an image cube, in contrast to the image pyramid. The resulting increase in storage space is largely compensated by the following benefits: objects of any size can be culled in constant time against an occlusion map using four depth lookups; visibility-like queries can be performed in vertex and fragment programs; N-buffers can be computed very efficiently with graphics hardware. We present three applications of this datastructure, and in particular a novel approach for shadow volume acceleration.
Mots clés
final-electronic.pdf (2.24 Mo) Télécharger le fichier
nbuffer05.ppt (7.71 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00510154 , version 1 (13-10-2010)
  • HAL Id : inria-00510154 , version 1
Xavier Décoret. N-Buffers for efficient depth map query. Computer Graphics Forum, 2005, 24 (3). ⟨inria-00510154⟩
344 Consultations
513 Téléchargements
