Billboard Clouds for Extreme Model Simplification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We introduce billboard clouds -- a new approach for extreme simplification in the context of real-time rendering. 3D models are simplified onto a set of planes with texture and transparency maps. We present an optimization approach to build a billboard cloud given a geometric error threshold. After computing an appropriate density function in plane space, a greedy approach is used to select suitable representative planes. A good surface approximation is ensured by favoring planes that are ``nearly tangent'' to the model. This method does not require connectivity information, but instead avoids cracks by projecting primitives onto multiple planes when needed. For extreme simplification, our approach combines the strengths of mesh decimation and image-based impostors. We demonstrate our technique on a large class of models, including smooth manifolds and composite objects.
bc03.pdf (2.32 Mo) Télécharger le fichier
BC-FastForwardSiggraph03.ppt (1.5 Mo) Télécharger le fichier
BC-poster.ppt (3.78 Mo) Télécharger le fichier
BC02_results.avi (22.98 Mo) Télécharger le fichier
Eiffel.avi (4.51 Mo) Télécharger le fichier
SIG03-presentation.ppt (3.67 Mo) Télécharger le fichier
socg.avi (20.36 Mo) Télécharger le fichier
socg.mpg (36.79 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00510175 , version 1 (13-10-2010)
  • HAL Id : inria-00510175 , version 1
Xavier Décoret, Frédo Durand, François X. Sillion, Julie Dorsey. Billboard Clouds for Extreme Model Simplification. Proceedings of the ACM Siggraph, 2003, San diego, United States. ⟨inria-00510175⟩
414 Consultations
870 Téléchargements
