Implicit Modelling Using Subdivision-curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Visual Computer Année : 2003
To remain an attractive model, skeleton-based implicit surfaces have to allow the design and display of shapes at interactive rates. This paper focuses on surfaces whose skeletons are graphs of interconnected curves. We present subdivision-curve primitives that rely on convolution for generating bulge-free and crease-free implicit surfaces. These surfaces are efficiently yet correctly displayed using local meshes around each curve that locally overlap in blending regions. Subdivision-curve primitives offer a practical solution to the unwanted-blending problem that ensures $C^1$ continuity everywhere. Moreover, they can be used to generate representations at different levels of detail, enabling the interactive display of at least a coarse version of the objects, whatever the performance of the workstation. We also present a practical solution to the unwanted blending problem, used to avoid blending between parts of the surface that do not correspond to neighbouring skeletal elements.
implicitSubCurves.pdf (432.2 Ko) Télécharger le fichier
Format : Figure, Image
inria-00510180 , version 1 (14-10-2010)
  • HAL Id : inria-00510180 , version 1
Samuel Hornus, Alexis Angelidis, Marie-Paule Cani. Implicit Modelling Using Subdivision-curves. The Visual Computer, 2003, 19 (2-3), pp.94-104. ⟨inria-00510180⟩
343 Consultations
262 Téléchargements
