A Computer-Assisted Colorization Algorithm based on Topological Difference
Region-based approaches to cel painting typically use shape similarity and topology relations between regions of consecutive animation frames. This paper presents a new colorization algorithm based on topological differences defined over a hierarchical graph of adjacent regions, which allows an almost full automatic colorization process. Also this paper discusses other attributes that improve the solution of the image association problem.
BFV06.pdf (373.91 Ko)
Télécharger le fichier
Format : Figure, Image
