Plausible Image Based Soft Shadows Using Occlusion Textures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a novel image-based approach to render plausible soft shadows for complex dynamic scenes with rectangular light sources. The algorithm's performance is mostly independent of the scene complexity and the source's size. Occluders and receivers do not need to be separated and no knowledge about the scene representation is required, making the method easy to use. The main idea is to approximate the occlusion in the scene with pre- filtered occlusion textures. The visibility of the light source at a point in space is estimated by accumulating the occlusion caused by each texture, using a novel formula based on probabilities.
pib06.pdf (860.99 Ko) Télécharger le fichier
video-pib06-HD.avi (16.48 Mo) Télécharger le fichier
video-pib06.avi (11.09 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510226 , version 1 (13-10-2010)
  • HAL Id : inria-00510226 , version 1
Elmar Eisemann, Xavier Décoret. Plausible Image Based Soft Shadows Using Occlusion Textures. Proceedings of the Brazilian Symposium on Computer Graphics and Image Processing, 19 (SIBGRAPI), IEEE, 2006, Manaus, Brazil. ⟨inria-00510226⟩
348 Consultations
353 Téléchargements
