Realistic Water Volumes in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present a real-time technique to render realistic water volumes. Water volumes are represented as the space enclosed between a ground heightfield and an animable water surface heightfield. This representation allows the application of recent GPU-based heightfield rendering algorithms. Our method is a simplified raytracing approach which correctly handles reflections and refractions and allows us to render complex effects such as light absorption, refracted shadows and refracted caustics. It runs at high framerates by exploiting the power of the latest graphic cards, and could be used in real-time applications like video games, or interactive simulation.
article.pdf (444.58 Ko) Télécharger le fichier
water06.avi (14.65 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00510227 , version 1 (24-11-2010)
  • HAL Id : inria-00510227 , version 1
Lionel Baboud, Xavier Décoret. Realistic Water Volumes in Real-Time. Eurographics Workshop on Natural Phenomena, Eurographics, 2006, Vienne, Austria. ⟨inria-00510227⟩
474 Consultations
1262 Téléchargements
