Non-Linear Aperture for Stylized Depth of Field
We introduce in this paper non-linear apertures that produce stylized depth of field from lightfield data. A non linear aperture is similar in spirit to the conventional aperture of a camera, except that it replaces the blur of shallow depth of field by a more complex detail removal filtering. The resulting non-realistic apertures produce stylized images where the amount of abstraction varies automatically with depth.
main_lightfield.pdf (159.93 Ko)
Télécharger le fichier
ball_median.wmv (2.49 Mo)
supplemental.pdf (2.88 Mo)
synthetic_bilateral.wmv (2.08 Mo)
synthetic_median.wmv (2.26 Mo)
truck_bilateral.wmv (2.48 Mo)
truck_edges.wmv (3.54 Mo)
truck_median.wmv (2.65 Mo)
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
