Mutation-based Model Synthesis in Model Driven Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
With the increasing use of models for software development and the emergence of model-driven engineering, it has become important to build accurate and precise models that present certain characteristics. Model transformation testing is a domain that requires generating a large number of models that satisfy coverage properties (cover the code of the transformation or the structure of the metamodel). However, manually building a set of models to test a transformation is a tedious task and having an automatic technique to generate models from a metamodel would be very helpful. We investigate the synthesis of models based on plans. Each plan comprises of a sequence of model synthesis rules (or mutation operators) specified as graph grammar (GG) rules. These mutation operators are primitive GG rules , automatically obtained from any meta-model. Such plans can be evolved by various artificial intelligence techniques to generate useful models for different tasks including model transformation testing.
sen06.pdf (1.13 Mo) Télécharger le fichier
inria-00512551 , version 1 (30-08-2010)
  • HAL Id : inria-00512551 , version 1
Sagar Sen, Benoit Baudry. Mutation-based Model Synthesis in Model Driven Engineering. Mutation'06 workshop associtaed to ISSRE'06, 2006, Raleigh, NC, USA, United States. ⟨inria-00512551⟩
108 Consultations
171 Téléchargements
