Multiple Birth and Cut Algorithm for Point Process Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ahmed Gamal Eldin
  • Fonction : Auteur
  • PersonId : 879000
X. Descombes
Josiane Zerubia
In this paper, we describe a new optimization method which we call Multiple Birth and Cut (MBC). It combines the recently developed Multiple Birth and Death (MBD) algorithm and the Graph-Cut algorithm. MBD and MBC optimization methods are applied to the energy minimization of an object based model, the marked point process. We compare the MBC to the MBD showing the advantages and disadvantages, where the most important advantage is the reduction of the number of parameters. We validated our algorithm on the counting problem of flamingos in colony, where our algorithm outperforms the performance of the MBD algorithm.
paper.pdf (1.39 Mo) Télécharger le fichier
inria-00516305 , version 1 (09-09-2010)
inria-00516305 , version 2 (21-09-2010)
inria-00516305 , version 3 (15-10-2010)
  • HAL Id : inria-00516305 , version 2
Ahmed Gamal Eldin, X. Descombes, Josiane Zerubia. Multiple Birth and Cut Algorithm for Point Process Optimization. Signal-Image Technology and Internet-Based Systems (SITIS 2010), Dec 2010, Kuala Lumpur, Malaysia. ⟨inria-00516305v2⟩
262 Consultations
434 Téléchargements
