Using Spatial Relations for Graphical Symbol Description - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we address the use of unified spatial relations for symbol description. We present a topologically guided directional relation signature. It references a unique point set instead of one entity in a pair, thus avoiding problems related to erroneous choices of reference entities and preserves symmetry. We experimentally validate our method on showing its ability to serve in a symbol retrieval application, based only on a spatial relational descriptor that represents the links between the decomposed structural patterns called “vocabulary” in a spatial relational graph.
ICPR_santosh.pdf (252.54 Ko) Télécharger le fichier
inria-00516725 , version 1 (11-09-2010)
Santosh K.C., Laurent Wendling, Bart Lamiroy. Using Spatial Relations for Graphical Symbol Description. 20th International Conference on Pattern Recognition - ICPR 2010, Aug 2010, Istanbul, Turkey. pp.2041 - 2044, ⟨10.1109/ICPR.2010.503⟩. ⟨inria-00516725⟩
211 Consultations
265 Téléchargements
