Fault detection with bayesian network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
The purpose of this chapter is to present a method for the fault detection in multivariate process, with a bayesian network. In this context, the detection is viewed as a classification task like the discriminant analysis, which can be transposed in a bayesian network. We prove mathematically the equivalence between the usual detection methods that are the multivariate control charts (Hotelling's T², MEWMA) and the quadratic discriminant analysis (in a bayesian network). So, this makes possible the fault detection with a bayesian network. An application on the Tennessee Eastman Process is given in order to demonstrate the approach.
verron08c.pdf (511.52 Ko) Télécharger le fichier
inria-00517063 , version 1 (13-09-2010)
  • HAL Id : inria-00517063 , version 1
Sylvain Verron, Teodor Tiplica, Abdessamad Kobi. Fault detection with bayesian network. Alexander Zemliak. Frontiers in Robotics, Automation and Control, IN-TECH, 2008, 9789537619176. ⟨inria-00517063⟩
Collections
UNIV-ANGERS
183 Consultations
714 Téléchargements
