Implicit Representations of the Human Intestines for Surgery Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
In this paper, we propose a modeling of the intestines by implicit surfaces for abdominal surgery simulation. The difficulty of such a simulation comes from the animation of the intestines. As a matter of fact, the intestines are a very long tube that is not isotropically elastic, and that bends over itself at various spots, creating multiple self-contacts. We use a multiple component model for the intestines: The first component is a mechanical model of their axis; the second component is a specific sphere-based model to manage collisions and self-collisions; and the third component is a skinning model to define their volume. This paper focuses on the better representation for skinning the intestines. We compare two implicit models: Surfaces defined by point-skeletons and convolution surfaces. A direct application of this simulation is the training of a typical surgical gesture to move apart the intestines in order to reach certain areas of the abdomen.
france_ms4cms02.pdf (214.99 Ko) Télécharger le fichier
Format : Figure, Image
inria-00517243 , version 1 (14-09-2010)
  • HAL Id : inria-00517243 , version 1
Laure France, Alexis Angelidis, Philippe Meseure, Marie-Paule Cani, Julien Lenoir, et al.. Implicit Representations of the Human Intestines for Surgery Simulation. Modelling and Simulation for Computer-aided Medicine and Surgery, MS4CMS, Nov 2002, Rocquencourt, France. ⟨inria-00517243⟩
1003 Consultations
99 Téléchargements
