A Framework for Seamless Computer Supported Cooperative Work in Three-Dimensional Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Jun-Hai Yong
  • Fonction : Auteur
A framework for computer supported cooperative design is proposed in this paper. With the system customization, the cooperation could be seamless. Namely, cooperation conflictions are detected automatically, and the designers are able to customize the system to handle the conflictions fully automatically. In this way, the designers can work on a large threedimensional mechanical part together freely, and obtain the result quickly. The communication of CAD data is based on a feature array, which greatly reduces the network burden, and speeds up the cooperative design. The procedure of the cooperation can be replayed or modified with the feature array as well.
Yong2005c.pdf (525.5 Ko) Télécharger le fichier
inria-00517627 , version 1 (15-09-2010)
  • HAL Id : inria-00517627 , version 1
Jun-Hai Yong. A Framework for Seamless Computer Supported Cooperative Work in Three-Dimensional Design. Proceedings of the Ninth International Conference on Computer Supported Cooperative Work in Design, May 2005, Coventry, United Kingdom. ⟨inria-00517627⟩
25 Consultations
88 Téléchargements
