Computing the minimum distance between two Bézier curves - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Journal of Computational and Applied Mathematics Year : 2009
A sweeping sphere clipping method is presented for computing the minimum distance between two Bézier curves. The sweeping sphere is constructed by rolling a sphere with its center point along a curve. The initial radius of the sweeping sphere can be set as the minimum distance between an end point and the other curve. The nearest point on a curve must be contained in the sweeping sphere along the other curve, and all of the parts outside the sweeping sphere can be eliminated. A simple sufficient condition when the nearest point is one of the two end points of a curve is provided, which turns the curve/curve case into a point/curve case and leads to higher efficiency. Examples are shown to illustrate efficiency and robustness of the new method.
Xiao-DiaoChen2009a.pdf (1.14 Mo) Télécharger le fichier
Dates and versions
inria-00518351 , version 1 (17-09-2010)
Identifiers
Cite
Xiao-Diao Chen, Linqiang Chen, Yigang Wang, Gang Xu, Jun-Hai Yong, et al.. Computing the minimum distance between two Bézier curves. Journal of Computational and Applied Mathematics, 2009, 229 (1), pp.194-301. ⟨10.1016/j.cam.2008.10.050⟩. ⟨inria-00518351⟩
641 View
3071 Download
Share
