Exploitation de la monotonie des fonctions dans la propagation de contraintes sur intervalles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new interval constraint propagation algorithm, called MOnotonic Hull Consistency (Mohc), that exploits monotonicity of functions. The propagation is standard, but the Mohc-Revise procedure, used to filter/contract the variable domains w.r.t. an individual constraint, uses monotonic versions of the classical HC4- Revise and BoxNarrow procedures. Mohc-Revise appears to be the first adaptive revise procedure ever proposed in constraint programming. Also, when a function is monotonic w.r.t. every variable, Mohc-Revise is proven to compute the optimal/ sharpest box enclosing all the solutions of the corresponding constraint (hull consistency). Very promising experimental results suggest that Mohc has the potential to become an alternative to the state-of-the-art HC4 and Box algorithms.
araya.pdf (302.77 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00520371 , version 1 (23-09-2010)
  • HAL Id : inria-00520371 , version 1
Ignacio Araya, Bertrand Neveu, Gilles Trombettoni. Exploitation de la monotonie des fonctions dans la propagation de contraintes sur intervalles. JFPC 2010 - Sixièmes Journées Francophones de Programmation par Contraintes, Jun 2010, Caen, France. pp.23-31. ⟨inria-00520371⟩
217 Consultations
146 Téléchargements
