Neighborhood Structures for GPU-based Local Search Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Processing Letters Année : 2010
Local search algorithms are powerful heuristics for solving computationally hard problems in science and industry. In these methods, designing neighborhood operators to explore large promising regions of the search space may improve the quality of the obtained solutions at the expense of a high computation process. As a consequence, the use of GPU computing provides an efficient way to speed up the search. However, designing applications on GPU is still complex and many issues have to be faced. We provide a methodology to design and implement different neighborhood structures for LS algorithms on GPU. The work has been evaluated for binary problems and the obtained results are convincing both in terms of efficiency, quality and robustness of the provided solutions at run time.
Autre [cs.OH]
PPL.pdf (417.34 Ko) Télécharger le fichier
inria-00520461 , version 1 (23-09-2010)
Thé Van Luong, Nouredine Melab, El-Ghazali Talbi. Neighborhood Structures for GPU-based Local Search Algorithms. Parallel Processing Letters, 2010, 20 (4), pp.307-324. ⟨10.1142/S0129626410000260⟩. ⟨inria-00520461⟩
126 Consultations
463 Téléchargements
