Accurate Definition of Brain Regions Position Through the Functional Landmark Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In many application of functional Magnetic Resonance Imaging (fMRI), including clinical or pharmacological studies, the definition of the location of the functional activity between subjects is crucial. While current acquisition and normalization procedures improve the accuracy of the functional signal localization, it is also important to ensure that functional foci detection yields accurate results, and reflects between-subject variability. Here we introduce a fast functional landmark detection procedure, that explicitly models the spatial variability of activation foci in the observed population. We compare this detection approach to standard statistical maps peak extraction procedures: we show that it yields more accurate results on simulations, and more reproducible results on a large cohort of subjects. These results demonstrate that explicit functional landmark modeling approaches are more effective than standard statistical mapping for brain functional focus detection.
bsa_miccai.pdf (290.83 Ko) Télécharger le fichier
inria-00521909 , version 1 (28-09-2010)
  • HAL Id : inria-00521909 , version 1
Bertrand Thirion, Gaël Varoquaux, Jean-Baptiste Poline. Accurate Definition of Brain Regions Position Through the Functional Landmark Approach. 13th International Conference on Medical Image Computing and Computer Assisted Intervention, Sep 2010, Beijing, China. ⟨inria-00521909⟩
120 Consultations
159 Téléchargements
