Non Smooth Fracture Dynamics (NSFD) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present in this work a modeling approach and an associated numerical strategy both devoted to complex mechanical surface interactions. This approach together with the dedicated numerical strategy are referred as Non Smooth Fracture Dynamics (NSFD). From an applied point of view, this work concerns the comprehension, the prediction and the numerical simulation of dynamic fracture for a wide variety of materials and structures. The main contribution is the ability to predict an entire fracture process: crack initiation, growth, propagation of microcracks, coalescence, propagation of a microcrack, final rupture and post fracture behavior (e.g. frictional contact between created fragments after fracture).
abstract_905.pdf (844.4 Ko) Télécharger le fichier
inria-00522352 , version 1 (30-09-2010)
  • HAL Id : inria-00522352 , version 1
Vincent Acary, Frédéric Dubois, Yann Monerie. Non Smooth Fracture Dynamics (NSFD). ECCM IV - IV European Congress on Computational Mechanics: Solids, Structures and Coupled Problems in Engineering, http://www.eccm2010.org/, May 2010, Paris, France. ⟨inria-00522352⟩
220 Consultations
776 Téléchargements
