Dominance-Based Pareto-Surrogate for Multi-Objective Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mainstream surrogate approaches for multi-objective problems build one approximation for each objective. Mono-surrogate approaches instead aim at characterizing the Pareto front with a single model. Such an approach has been recently introduced using a mixture of regression Support Vector Machine (SVM) to clamp the current Pareto front to a single value, and one-class SVM to ensure that all dominated points will be mapped on one side of this value. A new mono-surrogate EMO approach is introduced here, relaxing the previous approach and modelling Pareto dominance within the rank-SVM framework. The resulting surrogate model is then used as a filter for offspring generation in standard Evolutionary Multi-Objective Algorithms, and is comparatively validated on a set of benchmark problems.
seal2010_dominanceMOsurrogate.pdf (151.95 Ko) Télécharger le fichier
inria-00522653 , version 1 (01-10-2010)
  • HAL Id : inria-00522653 , version 1
Ilya Loshchilov, Marc Schoenauer, Michèle Sebag. Dominance-Based Pareto-Surrogate for Multi-Objective Optimization. Simulated Evolution And Learning (SEAL-2010), Dec 2010, Kanpur, India. ⟨inria-00522653⟩
197 Consultations
714 Téléchargements
