A class of multilevel parallel preconditioning strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Laura Grigori
Pawan Kumar
  • Fonction : Auteur
  • PersonId : 853962
Frédéric Nataf
Ke Wang
In this paper, we introduce a class of recursive multilevel preconditioning strategies suited for solving large sparse linear systems of equations on modern day architectures. They are based on a reordering of the input matrix into a nested bordered block diagonal form, which allows a nested formulation of the preconditioners. The first one, which we refer to as nested SSOR (NSSOR), requires only the factorization of diagonal blocks at the innermost level of the recursive formulation. Hence, its construction is embarassingly parallel, and the memory requirements are very limited. Next two are nested versions of Modified ILU preconditioner with row sum (NMILUR) and colsum (NMILUC) property. We compare these methods in terms of iteration number, memory requirements, and overall solve time, with ILU(0) with natural ordering and nested dissection ordering, and MILU. We find that NSSOR compares favorably with ILU(0) with nested dissection ordering, while NMILUR and NMILUC outperform the other methods for certain matrices in our test set. It is proved that the NSSOR method is convergent when the input matrix is SPD. The preconditioners are designed to be suitable for parallel computing.
Dans ce papier nous décrivons une classe de préconditionneurs multiniveaux parallèles pour résoudre des systèmes linéaires de grande taille. Ils se basent sur une renumérotation de la matrice d'entrée en forme block diagonale bornée et emboitée, qui permet une définition emboitée des préconditionneurs. Nous prouvons qu'un des préconditionneurs, NSSOR, converge quand la matrice d'entrée est symmétrique et définie positive. Les préconditionneurs sont adaptés au calcul parallèle.
Paper.pdf (3.39 Mo) Télécharger le fichier
inria-00524110 , version 1 (06-10-2010)
  • HAL Id : inria-00524110 , version 1
Laura Grigori, Pawan Kumar, Frédéric Nataf, Ke Wang. A class of multilevel parallel preconditioning strategies. [Research Report] RR-7410, INRIA. 2010. ⟨inria-00524110⟩
523 Consultations
774 Téléchargements
