Model based design flow for implementing an Anti-Collision Radar detection system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In order to ensure and increase the safety and reliability of transport systems, these systems are becoming more and more intelligent. They integrate more and more sensors and communication systems. Each of these functionalities can be implemented on a System-on-Chip (SoC). These functionalities are carried out by massive computations. As the number of integrated functionalities increase in the transport systems, the design and implementation complexity also increases at a tremendous rate. Implementation of these functionalities can be carried out either via FPGAs or DSP (digital signal processors) platforms. FPGAs are considered the ideal choice as they accelerate the computations by executing the algorithms in a parallel manner. Actually the initial steps in existing design flows are the development of the complex algorithms; and then their manual implementation, which are daunting tasks. Change in the scale of the algorithm requires starting the implementation over from scratch which results in increase design time. Normally these steps are carried out by teams of different domains which could result in compatibility issues. We propose a high abstraction level design methodology for implementation of these algorithms in a graphical manner. The advantages offered by our approach aim to reduce time to make up or time to market. Changes in the nature of the algorithm can be easily carried out due to their graphical nature and the code can be generated automatically rapidly. Afterwards the implementation can be carried out on the target FPGA platforms.
itst09.pdf (1.22 Mo) Télécharger le fichier
inria-00525006 , version 1 (10-10-2010)
  • HAL Id : inria-00525006 , version 1
Imran Rafiq Quadri, Yassin El Hillali, Samy Meftali, Jean-Luc Dekeyser. Model based design flow for implementing an Anti-Collision Radar detection system. 9th International IEEE Conference on ITS Telecommunications (ITS-T 2009), Oct 2009, Lille, France. ⟨inria-00525006⟩
166 Consultations
189 Téléchargements
