High level modeling of Partially Dynamically Reconfigurable FPGAs based on MDE and MARTE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
System-on-Chip (SoC) architectures are becoming the preferred solution for implementing modern embedded systems. However their design complexity continues to augment due to the increase in integrated hardware resources requiring new design methodologies and tools. In this paper we present a novel SoC co-design methodology based on aModel Driven Engineering framework while utilizing the MARTE (Modeling and Analysis of Real-time and Embedded Systems) standard. This methodology permits us to model fine grain reconfigurable architectures such as FPGAs and allows to extend the standard for integrating new features such as Partial Dynamic Reconfiguration supported by modern FPGAs. The overall objective is to carry out modeling at a high abstraction level expressed in a graphical language like UML (Unified Modeling Language) and afterwards transformations of these models, automatically generate the necessary specifications required for FPGA implementation.
recosoc08.pdf (1.4 Mo) Télécharger le fichier
inria-00525008 , version 1 (10-10-2010)
  • HAL Id : inria-00525008 , version 1
Imran Rafiq Quadri, Samy Meftali, Jean-Luc Dekeyser. High level modeling of Partially Dynamically Reconfigurable FPGAs based on MDE and MARTE. Reconfigurable Communication-centric SoCs (ReCoSoC'08), Jul 2008, Barcelona, Spain. ⟨inria-00525008⟩
103 Consultations
76 Téléchargements
