Dynamic Painting of Animated 3D scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2006
Painterly rendering is a technique that takes inspiration from traditional painting, such as oil or acrylic. The main idea is to render a 3D scene with 2D strokes in image space. Creating hand made painterly animations is very time-consuming since each frame of the animation is usually obtained by adding some paint strokes over previous frames. With an automated system, a user can not only build his animation faster but can handle the temporal coherence of strokes via a frame-to-frame correspondence. In our system the strokes follow the motion of objects (as in Meier's system [Mei96]) and faithfully represent some of their properties (depth and reflectance), while enabling the user to specify a painting style.
npar-rc2.pdf (19.76 Mo) Télécharger le fichier
Format : Figure, Image
inria-00526617 , version 1 (15-10-2010)
  • HAL Id : inria-00526617 , version 1
David Vanderhaeghe, Pascal Barla, Joëlle Thollot, François X. Sillion. Dynamic Painting of Animated 3D scenes. 4th International Symposium on Non-Photorealistic Animation and Rendering : NPAR, Jun 2006, Annecy, France. ⟨inria-00526617⟩
296 Consultations
277 Téléchargements
