Reliability and performance optimization of pipelined real-time systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider pipelined real-time systems, commonly found in assembly lines, consisting of a chain of tasks executing on a distributed platform. Their processing is pipelined: each processor executes only one interval of consecutive tasks. We are therefore interested in minimizing both the input-output latency and the period. For dependability reasons, we are also interested in maximizing the reliability of the system. We therefore assign several processors to each interval of tasks, so as to increase the reliability of the system. We assume that both processors and communication links are unreliable and subject to transient failures, the arrival of which follows a constant parameter Poisson law. We also assume that the failures are statistically independent events. We study several variants of this multiprocessor mapping problem with several hypotheses on the target platform (homogeneous/heterogeneous speeds and/or failure rates). We provide NP-hardness complexity results, and optimal mapping algorithms for polynomial problem instances.
icpp.pdf (1.51 Mo) Télécharger le fichier
inria-00526741 , version 1 (15-10-2010)
  • HAL Id : inria-00526741 , version 1
Anne Benoit, Fanny Dufossé, Alain Girault, Yves Robert. Reliability and performance optimization of pipelined real-time systems. International Conference on Parallel Processing, Sep 2010, San Diego, United States. pp.20. ⟨inria-00526741⟩
290 Consultations
128 Téléchargements
