Generation of Component Based Architecture from Business Processes: Model Driven Engineering for SOA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Karim Dahman
  • Fonction : Auteur
  • PersonId : 880821
François Charoy
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Service-Oriented Architecture (SOA) has significantly enhanced inter-organizational systems enabling business flexibility, Information Technology (IT) agility, and value generation. However, building a SOA that reduces technology-driven business and leverages process management seems referring to the recurrent issues of business process logic and IT alignment. This paper presents a model-driven development approach where long-running business service composition models drive their supporting service implementation models. To progress on the successful route to a SOA engineering with minimal design decisions losses, we propose a model-to-model transformation that preserves the architectural alignment between the business process and their supporting service implementation infrastructure. The result of the transformation is a component configuration model based on a SOA. It promotes the separation of business concerns, enabling quick and localized evolutions of the IT infrastructure.
Generation_of_Component_Based_Architecture_from_Business_Processes.pdf (384.64 Ko) Télécharger le fichier
inria-00527476 , version 1 (19-10-2010)
  • HAL Id : inria-00527476 , version 1
Karim Dahman, François Charoy, Claude Godart. Generation of Component Based Architecture from Business Processes: Model Driven Engineering for SOA. ECOWS 2010 - The 8th IEEE European Conference on Web Services Welcome, Dec 2010, Ayia Napa, Greece. ⟨inria-00527476⟩
140 Consultations
455 Téléchargements
