Matching of Asymptotic Expansions for a 2-D eigenvalue problem with two cavities linked by a narrow hole - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
One question of interest in an industrial conception of air planes motors is the study of the deviation of the acoustic resonance frequencies of a cavity which is linked to another one through a thin slot. These frequencies have a direct impact on the stability of the combustion in one of these two cavities. In this work, we aim is analyzing the eigenvalue problem for the Laplace operator with Dirichlet boundary conditions. Using the Matched Asymptotic Expansions technique, we derive the Asymptotic Expansion of this eigenmodes. Then, these results are validated through error estimates. Finally, we show how we can design a numerical method to compute the eigenvectors of this problem. The results are compared with direct computations.
WAVES2009slides.pdf (3.25 Mo) Télécharger le fichier
WAVES2009abstract.pdf (61.05 Ko) Télécharger le fichier
inria-00527896 , version 1 (20-10-2010)
  • HAL Id : inria-00527896 , version 1
Abderrahmane Bendali, Abdelkader Tizaoui, Sébastien Tordeux. Matching of Asymptotic Expansions for a 2-D eigenvalue problem with two cavities linked by a narrow hole. WAVES, INRIA Bordeaux Sud-Ouest et Université de Pau, 2009, Pau, France. ⟨inria-00527896⟩
118 Consultations
129 Téléchargements
