Snooze: A Scalable, Fault-Tolerant and Distributed Consolidation Manager for Large-Scale Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Louis Rilling
  • Function : Author
  • PersonId : 879795
Renaud Lottiaux
  • Function : Author
Daniel Leprince
  • Function : Author
  • PersonId : 879797
Intelligent workload consolidation and dynamic cluster adaptation offer a great opportunity for energy savings in current large-scale clusters. Because of the heterogeneous nature of these environments, scalable, fault-tolerant and distributed consolidation managers are necessary in order to efficiently manage their workload and thus conserve energy and reduce the operating costs. However, most of the consolidation managers available nowadays do not fulfill these requirements. Hence, they are mostly centralized and solely designed to be operated in virtualized environments. In this work, we present the architecture of a novel scalable, fault-tolerant and distributed consolidation manager called Snooze that is able to dynamically consolidate the workload of a software and hardware heterogeneous large-scale cluster composed out of resources using the virtualization and Single System Image (SSI) technologies. Therefore, a common cluster monitoring and management API is introduced, which provides a uniform and transparent access to the features of the underlying platforms. Our architecture is open to support any future technologies and can be easily extended with monitoring metrics and algorithms. Finally, a comprehensive use case study demonstrates the feasibility of our approach to manage the energy consumption of a large-scale cluster.
efeller.pdf (175.64 Ko) Télécharger le fichier
Dates and versions
inria-00529702 , version 1 (10-11-2011)
Identifiers
  • HAL Id : inria-00529702 , version 1
Cite
Eugen Feller, Louis Rilling, Christine Morin, Renaud Lottiaux, Daniel Leprince. Snooze: A Scalable, Fault-Tolerant and Distributed Consolidation Manager for Large-Scale Clusters. 2010 IEEE/ACM International Conference on Green Computing and Communications (GreenCom-2010), Dec 2010, Hangzhou, China. ⟨inria-00529702⟩
446 View
198 Download
Share
