Automatic IPv4 to IPv6 Transition D3.1 - Secured Transition Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2010
Over the last decade, IPv6 has established itself as the most mature network protocol for the future Internet. While its acceptance and deployment remained so far often limited to academic networks, its recent deployment in both core networks of operators (often for management purposes) and its availability to end customers of large ISPs demonstrates its deployment from the inside of the network leading to the edges. For many enterprises, the transition is seen as a tedious and error prone task for network administrators. In the context of the Cisco CCRI project, we aim at providing the necessary algorithms and tools to automate the transition. In this report, we present the security policy that must be deployed on the site in conjunction with the addressing plan.
deliverable-3.1.pdf (609.89 Ko) Télécharger le fichier
inria-00531209 , version 1 (02-11-2010)
  • HAL Id : inria-00531209 , version 1
Frédéric Beck, Isabelle Chrisment, Olivier Festor. Automatic IPv4 to IPv6 Transition D3.1 - Secured Transition Engine. [Contract] 2010, pp.37. ⟨inria-00531209⟩
129 Consultations
42 Téléchargements
