STRONG AND WEAK SEMICLASSICAL LIMIT FOR SOME ROUGH HAMILTONIANS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2012
We present several results concerning the semiclassical limit of the time dependent Schrödinger equation with potentials whose regularity doesn't guarantee the uniqueness of the underlying classical flow. Different topologies for the limit are considered and the situation where two bicharateristics can be obtained out of the same initial point is emphasized.
REV_7.pdf (431.86 Ko) Télécharger le fichier
inria-00533558 , version 1 (07-11-2010)
inria-00533558 , version 2 (17-11-2010)
inria-00533558 , version 3 (17-11-2010)
inria-00533558 , version 4 (25-11-2010)
inria-00533558 , version 5 (01-12-2010)
inria-00533558 , version 6 (28-01-2011)
inria-00533558 , version 7 (02-02-2011)
inria-00533558 , version 8 (06-08-2011)
Agissilaos Athanassoulis, Thierry Paul. STRONG AND WEAK SEMICLASSICAL LIMIT FOR SOME ROUGH HAMILTONIANS. Mathematical Models and Methods in Applied Sciences, 2012, 22 (12), pp.1250038. ⟨10.1142/S0218202512500388⟩. ⟨inria-00533558v8⟩
260 Consultations
206 Téléchargements
