Strong and weak semiclassical limits for some rough Hamiltonians - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2010
Thierry Paul
  • Function : Author
  • PersonId : 878449
  • IdRef : 158973372
We present several results concerning the semiclassical limit of the time dependent Schrödinger equation with potentials whose regularity doesn't guarantee the uniqueness of the underlying classical flow. Different topologies for the limit are considered and the situation where two bicharateristics can be obtained out of the same initial point is emphasized.
aatprough6b.pdf (277.46 Ko) Télécharger le fichier
Dates and versions
inria-00533558 , version 1 (07-11-2010)
inria-00533558 , version 2 (17-11-2010)
inria-00533558 , version 3 (17-11-2010)
inria-00533558 , version 4 (25-11-2010)
inria-00533558 , version 5 (01-12-2010)
inria-00533558 , version 6 (28-01-2011)
inria-00533558 , version 7 (02-02-2011)
inria-00533558 , version 8 (06-08-2011)
Identifiers
  • HAL Id : inria-00533558 , version 3
Cite
Agissilaos Athanassoulis, Thierry Paul. Strong and weak semiclassical limits for some rough Hamiltonians. 2010. ⟨inria-00533558v3⟩
266 View
207 Download
Share
