Generic Face Animation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mauricio Cerda
  • Fonction : Auteur
  • PersonId : 843075
Renato Valenzuela
  • Fonction : Auteur
  • PersonId : 882783
In computer vision, the animation of objects has attracted a lot attention, specially the animations of 3D face models. The animation of face models requires in general to manually adapt each generic movement (open/close mouth) to each specific head geometry. In this work we propose a technique for the animation of any face model avoiding most of the manual intervention. In order to achieve this we assume that: (1) faces, despite obvious differences are quite similar and a single generic model can be used to simplify deformations and (2) using this face model, a simple interpolation technique can be used, with minimal manual intervention. Several examples are presented to verify the realism of the obtained animations.
animation.pdf (283.06 Ko) Télécharger le fichier
inria-00536958 , version 1 (17-11-2010)
  • HAL Id : inria-00536958 , version 1
Mauricio Cerda, Renato Valenzuela, Nancy Hitschfeld-Kahler, Lucas Terissi, Juan C. Gomez. Generic Face Animation. XXIX International Conference of the Chilean Computer Society, SCCC, Nov 2010, Antofagasta, Chile. pp.252-257. ⟨inria-00536958⟩
164 Consultations
566 Téléchargements
