Comparing the performance of two TAG-based surface realisers using controlled grammar traversal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present GENSEM, a tool for generating input semantic representations for two sentence generators based on the same reversible Tree Adjoining Grammar. We then show how GENSEM can be used to produced large and controlled benchmarks and test the relative performance of these generators.
gargotper-coling10.pdf (82.25 Ko) Télécharger le fichier
inria-00537017 , version 1 (17-11-2010)
inria-00537017 , version 2 (11-03-2011)
  • HAL Id : inria-00537017 , version 1
Claire Gardent, Benjamin Gottesman, Laura Perez-Beltrachini. Comparing the performance of two TAG-based surface realisers using controlled grammar traversal. Coling 2010: Posters, Aug 2010, Beijing, China. ⟨inria-00537017v1⟩
124 Consultations
100 Téléchargements
